I am very keen to connect a couple of inductive proximity sensors http://www.automationdirect.com/static/specs/prox8mmae.pdf to AB quadratic encoder inputs. They operate at 30Khz which is significantly more than I need with 6 counts per revolution and less than 3000RPM spindle.
I am running them from a 24V source and I do not want to harm my KAnalog / Kflop boards so I thought I would check with you first.
The actual output is less than 24V but if we presume it is 24 then: would a 3KOhm resistor resulting in 3.25V across the 470Ohm that is across the inputs make this safe for the Dynomotion boards?
Is there a specific voltage I should be aiming for?
I cant see a current limit recommended by you so based on search I have found 10mA recommended for some LVTTL and my sums give this above. Please advise.
Eagerly waiting to thread...
Jon
